<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Power management issue M5GO &amp; USB host]]></title><description><![CDATA[<p dir="auto">Hi.<br />
I have a setup with M5Core with the USB host module and GO battery.</p>
<p dir="auto">My issues are as follows:<br />
I use M5.poweroff after a timeout, but does not seem like the usb module powers off.<br />
There is a significant power drain somewhere.</p>
<p dir="auto">When the battery is depleted the M5 will not start up again, even if I fully charge the GO.<br />
Only way to wake it is to put power into the M5 USBC connector.</p>
<p dir="auto">Does anyone have a suggestion?</p>
]]></description><link>https://community.m5stack.com/topic/1706/power-management-issue-m5go-usb-host</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 22:19:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1706.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Feb 2020 10:38:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Power management issue M5GO &amp; USB host on Fri, 21 Feb 2020 08:12:10 GMT]]></title><description><![CDATA[<p dir="auto">When you stack USB modules, the current will change slightly, which may cause some effects. Also related to your configuration of IP5306</p>
]]></description><link>https://community.m5stack.com/post/7500</link><guid isPermaLink="true">https://community.m5stack.com/post/7500</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 21 Feb 2020 08:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to Power management issue M5GO &amp; USB host on Thu, 20 Feb 2020 09:06:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi again.</p>
<p dir="auto">I have experimented a lot now, my current power settings are as follows:</p>
<p dir="auto">M5.Power.setPowerBoostOnOff(false); 	//Change the power on / off method. The power does not turn off when connected via USB. true=Press and hold to turn on / off. false=Turn on / off with two short presses.<br />
M5.Power.setPowerBoostSet(true);		//Change the power on / off method true=ON / OFF in one short press. false=same as above<br />
M5.Power.setPowerVin(true);				//When the power supply from USB etc. is cut off, Decide whether to turn on the power again.<br />
M5.Power.setPowerBtnEn(true);			//Set whether to accept the power button.<br />
M5.Power.setPowerBoostKeepOn(false); 	//Always output power. True= Always output power. False=not Always output power.<br />
M5.Power.setAutoBootOnLoad(true);		//Set whether to automatically start when power consumption occurs</p>
<p dir="auto">This lets me turn the M5 off/on with the power button with single click. However, it does NOT work if the USB HOST module is connected.<br />
I can turn it off, but it never turns on again, until I connect usb to the M5core directly.</p>
]]></description><link>https://community.m5stack.com/post/7496</link><guid isPermaLink="true">https://community.m5stack.com/post/7496</guid><dc:creator><![CDATA[option]]></dc:creator><pubDate>Thu, 20 Feb 2020 09:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to Power management issue M5GO &amp; USB host on Wed, 19 Feb 2020 13:57:11 GMT]]></title><description><![CDATA[<p dir="auto">Mine only reboot if I try to turn it off by double click.</p>
<p dir="auto">Is there a way to actually turn it off from software?</p>
]]></description><link>https://community.m5stack.com/post/7476</link><guid isPermaLink="true">https://community.m5stack.com/post/7476</guid><dc:creator><![CDATA[option]]></dc:creator><pubDate>Wed, 19 Feb 2020 13:57:11 GMT</pubDate></item><item><title><![CDATA[Reply to Power management issue M5GO &amp; USB host on Wed, 19 Feb 2020 13:05:19 GMT]]></title><description><![CDATA[<p dir="auto">M5.poweroff simply puts the ESP32 into sleep mode. if you want to turn off the device , you only can doulble click the power button</p>
]]></description><link>https://community.m5stack.com/post/7474</link><guid isPermaLink="true">https://community.m5stack.com/post/7474</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 19 Feb 2020 13:05:19 GMT</pubDate></item></channel></rss>
