<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[unable to flash after loading arduino tetris]]></title><description><![CDATA[<p dir="auto">gray m5 core</p>
<p dir="auto">Win7 - loaded tetris from arduino UI successfully. no trying to re-flash anything from  arduino or m5burner it looks like the tetris load does not let the bootloader start. on any load attempt the system resets and then the tetris start screen appears. this repeats till the loader times out trying to connect. forcing a reset via the power button has no difference than the usb induced reset</p>
]]></description><link>https://community.m5stack.com/topic/1696/unable-to-flash-after-loading-arduino-tetris</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 12:05:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1696.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Feb 2020 20:12:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to unable to flash after loading arduino tetris on Fri, 14 Feb 2020 03:05:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daavery" aria-label="Profile: daavery">@<bdi>daavery</bdi></a> You can try more times on win7, maybe just baud rate issue or USB COM / cable issue.</p>
]]></description><link>https://community.m5stack.com/post/7389</link><guid isPermaLink="true">https://community.m5stack.com/post/7389</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 14 Feb 2020 03:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to unable to flash after loading arduino tetris on Fri, 14 Feb 2020 02:08:12 GMT]]></title><description><![CDATA[<p dir="auto">solved...sort of ...    looks to be win7 problem - works fine on up to date win 10</p>
]]></description><link>https://community.m5stack.com/post/7388</link><guid isPermaLink="true">https://community.m5stack.com/post/7388</guid><dc:creator><![CDATA[daavery]]></dc:creator><pubDate>Fri, 14 Feb 2020 02:08:12 GMT</pubDate></item><item><title><![CDATA[Reply to unable to flash after loading arduino tetris on Thu, 13 Feb 2020 22:46:33 GMT]]></title><description><![CDATA[<p dir="auto">from arduino serial monitor @ 115200 baud :</p>
<h1>==========================<br />
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)<br />
mode:DIO, clock div:1<br />
load:0x3fff0018,len:4<br />
load:0x3fff001c,len:1216<br />
ho 0 tail 12 room 4<br />
load:0x40078000,len:9720<br />
load:0x40080400,len:6352<br />
entry 0x400806b8<br />
M5Stack initializing...OK</h1>
<p dir="auto">so the serial port seems to be working OK - but  loader never connects</p>
]]></description><link>https://community.m5stack.com/post/7387</link><guid isPermaLink="true">https://community.m5stack.com/post/7387</guid><dc:creator><![CDATA[daavery]]></dc:creator><pubDate>Thu, 13 Feb 2020 22:46:33 GMT</pubDate></item></channel></rss>
