<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New to M5Stack... A few questions about UIFlow]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am new to this community. I started to develop an UI using UIFlow to show MQTT data from my home automation server.</p>
<p dir="auto">However despite all my digging I could not answer the following:</p>
<li>
<p dir="auto">When I add Python code to UIFlow, I get an error message stating that the Blockly tab does not correspond to the Python code. Which is normal since I "hard code" additional stuff. Any fix for that?</p>
</li>
<li>
<p dir="auto">MQTT seems to cause some issues: when I use PahoMQTT to publish multiple messages, the M5Stack does not receive them. I have to make an individual connection for each publish that I want to show on the M5Stack. Same issue for retained messages: once a retained message is published, the M5Stack simply won't connect to the broker anymore. May I know what protocol for MQTT is behind UIFlow? This may be the issue.</p>
</li>
<li>
<p dir="auto">I do not find a way to turn the screen off and get some power saving mode in UIFlow. Are light sleep and deep sleep available, and if so is there a simple sample code to show how a button press can switch sleep mode until another button press wakes the device up?</p>
</li>
<p dir="auto">Thanks a lot for your support to all these,</p>
<p dir="auto">Regards,</p>
]]></description><link>https://community.m5stack.com/topic/1631/new-to-m5stack-a-few-questions-about-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 17:38:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1631.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Jan 2020 05:55:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New to M5Stack... A few questions about UIFlow on Sat, 18 Jan 2020 11:11:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meatpuppet" aria-label="Profile: meatpuppet">@<bdi>meatpuppet</bdi></a> the problem is that while I am working on documents, I haven’t had time too look into the MQTT issues to see what’s happening (I’m not a coder so I can’t fix things) but when I have time I look into issues and give feedback to support. I see a lot of the same MQTT issues popping up and wish I could help. The 1.4.4 update caused a lot of issues, and so finding time to use and break things is something that needs a lot to f help and support from users. I am wondering if the current issues are due to connections between the device and the server.</p>
]]></description><link>https://community.m5stack.com/post/7104</link><guid isPermaLink="true">https://community.m5stack.com/post/7104</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 18 Jan 2020 11:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to New to M5Stack... A few questions about UIFlow on Sat, 18 Jan 2020 08:48:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for this quick first answer.</p>
<p dir="auto">Is it necessary to switch to another environment to get all these features? Such as ESP32 library on Arduino...</p>
]]></description><link>https://community.m5stack.com/post/7102</link><guid isPermaLink="true">https://community.m5stack.com/post/7102</guid><dc:creator><![CDATA[meatpuppet]]></dc:creator><pubDate>Sat, 18 Jan 2020 08:48:35 GMT</pubDate></item><item><title><![CDATA[Reply to New to M5Stack... A few questions about UIFlow on Sat, 18 Jan 2020 07:45:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meatpuppet" aria-label="Profile: meatpuppet">@<bdi>meatpuppet</bdi></a><br />
A1 you can try using the Execute code block but it only supports one line of code per block.<br />
A2 Unknown<br />
A3 Unknown</p>
]]></description><link>https://community.m5stack.com/post/7100</link><guid isPermaLink="true">https://community.m5stack.com/post/7100</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 18 Jan 2020 07:45:12 GMT</pubDate></item></channel></rss>
