<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[catch network problem]]></title><description><![CDATA[<p dir="auto">urequest hangs frequently, seems to be an unstable WLAN stack.<br />
Is it possible having a longer timeout using urequest, or is there some asynchronous version?<br />
If the connection fails. is there some return of the http status , does response.status_code work?<br />
How to display exceptions,  only via print(e)?<br />
The program seems to work better when not uploaded but started via RUN, however connection to the M5 Stack is only established via uploading the code to the device.</p>
]]></description><link>https://community.m5stack.com/topic/1567/catch-network-problem</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 06:02:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1567.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Dec 2019 20:40:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to catch network problem on Sun, 26 Apr 2020 05:17:38 GMT]]></title><description><![CDATA[<p dir="auto">I think that I'm running into something similar: When RUN from visual studio, it works great, but when I disconnect it and start standalone, it hangs shortly after connecting to WiFi. It seems that I can do one more print, and that's it.</p>
]]></description><link>https://community.m5stack.com/post/8371</link><guid isPermaLink="true">https://community.m5stack.com/post/8371</guid><dc:creator><![CDATA[dclaar]]></dc:creator><pubDate>Sun, 26 Apr 2020 05:17:38 GMT</pubDate></item><item><title><![CDATA[Reply to catch network problem on Sun, 05 Jan 2020 10:09:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> sometimes the program does not start when uploading into the m5stack as <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a>.</p>
]]></description><link>https://community.m5stack.com/post/6889</link><guid isPermaLink="true">https://community.m5stack.com/post/6889</guid><dc:creator><![CDATA[Efried]]></dc:creator><pubDate>Sun, 05 Jan 2020 10:09:27 GMT</pubDate></item><item><title><![CDATA[Reply to catch network problem on Wed, 01 Jan 2020 13:47:26 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried saving your program as <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> in the root of the device? or do you get the same issues if you download it and run it from the app menu?</p>
]]></description><link>https://community.m5stack.com/post/6824</link><guid isPermaLink="true">https://community.m5stack.com/post/6824</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 01 Jan 2020 13:47:26 GMT</pubDate></item></channel></rss>
