<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stick gets very hot with SPK and Charging &#x2F; USB unstable (newbie questions to experts)]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have sucessfully implemented my first two programs M5StickC. And somehow it does work and is very cool :) - however I have ran accoss some strange things that I did not find an answer to after searching this forum / the beginner / basics docs at <a href="https://docs.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com</a>:</p>
<li>
<p dir="auto">when charging the device with SPK module on it gets very hot - both the speaker and module. I only have one module here so I cannot check any combinations. Without USB Cable it is not getting hot, speaker works fine. =&gt; Is that normal? How can I reduce the heat?</p>
</li>
<li>
<p dir="auto">the usb-mode is not very stable. I have tried out many variations and have come to 9/10 times where download works but it is still annoying. Are there some tips to make USB download work every time?</p>
</li>
<p dir="auto">Thank you!</p>
<p dir="auto">MCHack</p>
]]></description><link>https://community.m5stack.com/topic/1552/stick-gets-very-hot-with-spk-and-charging-usb-unstable-newbie-questions-to-experts</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 08:27:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1552.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Dec 2019 09:21:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stick gets very hot with SPK and Charging &#x2F; USB unstable (newbie questions to experts) on Fri, 20 Dec 2019 16:55:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mchack" aria-label="Profile: mchack">@<bdi>mchack</bdi></a> widows does have issue but i'm worried that it could be connected to the heat issue.</p>
]]></description><link>https://community.m5stack.com/post/6754</link><guid isPermaLink="true">https://community.m5stack.com/post/6754</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 20 Dec 2019 16:55:59 GMT</pubDate></item><item><title><![CDATA[Reply to Stick gets very hot with SPK and Charging &#x2F; USB unstable (newbie questions to experts) on Fri, 20 Dec 2019 15:08:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi<br />
thank you for the quick answer.</p>
<p dir="auto">-So they are getting really hot  too hot - you can still touch them but it is surprisingly hot. and: when disconnecting the usb chable it is back to warm (whcih I get &amp; understand...)</p>
<li>The cable was inluded and looks ok.</li>
<li>The problem has worsed: All of a sudden, Windows claims it cannot recognise the device any more will have to reinstal the driver &amp; hope that helps. :(</li>
]]></description><link>https://community.m5stack.com/post/6751</link><guid isPermaLink="true">https://community.m5stack.com/post/6751</guid><dc:creator><![CDATA[MCHack]]></dc:creator><pubDate>Fri, 20 Dec 2019 15:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to Stick gets very hot with SPK and Charging &#x2F; USB unstable (newbie questions to experts) on Fri, 20 Dec 2019 14:52:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mchack" aria-label="Profile: mchack">@<bdi>mchack</bdi></a> they are getting hot because the amp in the speaker and the charge controller draw power.<br />
Intermittent usb is down to one of two things.</p>
<p dir="auto">1st is the usb lead. Try a good quality usb charge/sync cable.<br />
2nd is the driver. The driver can be temperamental if not installed properly as it will fight with the host OS version of the driver.</p>
]]></description><link>https://community.m5stack.com/post/6750</link><guid isPermaLink="true">https://community.m5stack.com/post/6750</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 20 Dec 2019 14:52:45 GMT</pubDate></item></channel></rss>
