<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SK6812 RGBW]]></title><description><![CDATA[<p dir="auto">Is there any option to use a 4color led on the M5 Stack ?</p>
<p dir="auto">I need as a Test-Device for installations</p>
]]></description><link>https://community.m5stack.com/topic/1547/sk6812-rgbw</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 14:55:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1547.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Dec 2019 01:41:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 17 May 2021 05:18:22 GMT]]></title><description><![CDATA[<p dir="auto">I heard from my supplier that SK6812RGBW has been stopped production  and updated to SC6812RGBW,SC6812RGBW quanlity is better than SK6812RGBW.<br />
Here is SC6812RGBW led datasheet:<a href="http://www.normandled.com/upload/202102/SC6812RGBW%20LED%20Datasheet.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.normandled.com/upload/202102/SC6812RGBW LED Datasheet.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/13803</link><guid isPermaLink="true">https://community.m5stack.com/post/13803</guid><dc:creator><![CDATA[samsonwood]]></dc:creator><pubDate>Mon, 17 May 2021 05:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 10:52:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a></p>
<p dir="auto">its have still 3 wire- but 4 channels every LED, so if you counter - need to set the numbers of channels to 4 instead of 3 for RGB<br />
<img src="/assets/uploads/files/1576493521759-img_4010-resized.jpg" alt="0_1576493516678_IMG_4010.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/6718</link><guid isPermaLink="true">https://community.m5stack.com/post/6718</guid><dc:creator><![CDATA[Henry Schmidt]]></dc:creator><pubDate>Mon, 16 Dec 2019 10:52:04 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 08:37:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/henry-schmidt" aria-label="Profile: henry-schmidt">@<bdi>henry-schmidt</bdi></a> HEIC format is not supported please use jpg file format.</p>
]]></description><link>https://community.m5stack.com/post/6716</link><guid isPermaLink="true">https://community.m5stack.com/post/6716</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 16 Dec 2019 08:37:48 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 07:45:07 GMT]]></title><description><![CDATA[<p dir="auto">The LED strips on our website are  supposed to be sk6812 but only have 3 lines <a href="https://m5stack.com/collections/m5-unit/products/neopixel-rgb-leds-cable" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-unit/products/neopixel-rgb-leds-cable</a> couldn't see your picture, are you saying your LED strip has 4 wires?</p>
]]></description><link>https://community.m5stack.com/post/6714</link><guid isPermaLink="true">https://community.m5stack.com/post/6714</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 16 Dec 2019 07:45:07 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 05:40:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> They do exist and are supposed to be more efficient then RGB versions.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/henry-schmidt" aria-label="Profile: Henry-Schmidt">@<bdi>Henry-Schmidt</bdi></a> My understanding was that they were usable without the need for code changes.</p>
]]></description><link>https://community.m5stack.com/post/6713</link><guid isPermaLink="true">https://community.m5stack.com/post/6713</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 16 Dec 2019 05:40:49 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 05:05:03 GMT]]></title><description><![CDATA[<p dir="auto">![0_1576472695584_IMG_4010.HEIC](Uploading 100%)</p>
]]></description><link>https://community.m5stack.com/post/6712</link><guid isPermaLink="true">https://community.m5stack.com/post/6712</guid><dc:creator><![CDATA[Henry Schmidt]]></dc:creator><pubDate>Mon, 16 Dec 2019 05:05:03 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 05:03:14 GMT]]></title><description><![CDATA[<p dir="auto">its a true 4channel IC, I use this for a high power brightness, the 4. channel is the Warmwhite or cold white, now I need to set to 4 channels each LED</p>
]]></description><link>https://community.m5stack.com/post/6711</link><guid isPermaLink="true">https://community.m5stack.com/post/6711</guid><dc:creator><![CDATA[Henry Schmidt]]></dc:creator><pubDate>Mon, 16 Dec 2019 05:03:14 GMT</pubDate></item><item><title><![CDATA[Reply to SK6812 RGBW on Mon, 16 Dec 2019 04:04:08 GMT]]></title><description><![CDATA[<p dir="auto">you can use SK6812 with m5stack device.  and your mean was SK6812 RGB right? i never hear "SK6812 RGBW" before.    are you sure this type ?</p>
]]></description><link>https://community.m5stack.com/post/6710</link><guid isPermaLink="true">https://community.m5stack.com/post/6710</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 16 Dec 2019 04:04:08 GMT</pubDate></item></channel></rss>
