<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Broplem with M5Go Batterie by buy from aliexpress]]></title><description><![CDATA[<p dir="auto">Hello, I'm having problems with port C. The unitLight sensor does not always give the analog value I think of a false contact with contacts barettes interior (2 * 15). If I screw the two hex screws, the analog input of port C no longer works. If I remove the screws the port C works normally. What can I do for me? See the video Thank you.</p>
<p dir="auto">I filed a dispute on Aliexpress and the problem is not recognized by M5Stack.</p>
<p dir="auto">The problem is not the charging of the battery. The battery is charging well<br />
It is a problem of receiving data on the port when the plastic box is screwed.<br />
When the screws are removed all is well.<br />
I think the problem is false contact.</p>
<p dir="auto">I test the M5Stack products for use with students and I want to have reliable products because I will buy a lot.</p>
<p dir="auto">What can you do to solve the problem?<br />
Thank you</p>
]]></description><link>https://community.m5stack.com/topic/1432/broplem-with-m5go-batterie-by-buy-from-aliexpress</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 05:46:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1432.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Oct 2019 13:01:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Broplem with M5Go Batterie by buy from aliexpress on Sun, 03 Nov 2019 10:55:12 GMT]]></title><description><![CDATA[<p dir="auto">After 3 successive orders, the bases have all three a defect of connectivity.<br />
I think the heights of the pins of the contacts are not high enough and do not fit in the header.<br />
View the photo :</p>
<p dir="auto"><img src="/assets/uploads/files/1572778477632-img_20191103_114636-resized.jpg" alt="0_1572778474127_IMG_20191103_114636.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/6248</link><guid isPermaLink="true">https://community.m5stack.com/post/6248</guid><dc:creator><![CDATA[lfleron]]></dc:creator><pubDate>Sun, 03 Nov 2019 10:55:12 GMT</pubDate></item></channel></rss>
