<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing module with my core M5 Basic ??]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I bought the core M5 Basic and I want to connect the light sensor with relay module (I want to do as the video presentation). But both have a Grove connection. I think I'm missing a connection module, but which one?<br />
Thanks for your help.</p>
]]></description><link>https://community.m5stack.com/topic/1374/missing-module-with-my-core-m5-basic</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 08:57:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1374.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Oct 2019 15:00:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Tue, 15 Oct 2019 11:37:19 GMT]]></title><description><![CDATA[<p dir="auto">I didn't say it was clean, it's a workaround. You can buy grove to dupont converters.<br />
<a href="https://www.aliexpress.com/item/32801421897.html?spm=a2g0o.productlist.0.0.4612d357XRyxy0&amp;algo_pvid=32f54ee3-80fd-47a2-8346-79292f9c97d6&amp;algo_expid=32f54ee3-80fd-47a2-8346-79292f9c97d6-22&amp;btsid=c43ffbaf-dfc6-4639-81cc-59bfa84bb838&amp;ws_ab_test=searchweb0_0,searchweb201602_6,searchweb201603_52" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/item/32801421897.html?spm=a2g0o.productlist.0.0.4612d357XRyxy0&amp;algo_pvid=32f54ee3-80fd-47a2-8346-79292f9c97d6&amp;algo_expid=32f54ee3-80fd-47a2-8346-79292f9c97d6-22&amp;btsid=c43ffbaf-dfc6-4639-81cc-59bfa84bb838&amp;ws_ab_test=searchweb0_0,searchweb201602_6,searchweb201603_52</a></p>
]]></description><link>https://community.m5stack.com/post/5979</link><guid isPermaLink="true">https://community.m5stack.com/post/5979</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 15 Oct 2019 11:37:19 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Tue, 15 Oct 2019 11:25:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a><br />
The solution you mention is not clean.<br />
It takes a cable groove &lt;--&gt; Dupont.</p>
]]></description><link>https://community.m5stack.com/post/5978</link><guid isPermaLink="true">https://community.m5stack.com/post/5978</guid><dc:creator><![CDATA[lfleron]]></dc:creator><pubDate>Tue, 15 Oct 2019 11:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Fri, 11 Oct 2019 19:59:31 GMT]]></title><description><![CDATA[<p dir="auto">usually you can get around it by cracking the plastic off one of the dupont female connectors, its a sketchy workaround but it works for me</p>
]]></description><link>https://community.m5stack.com/post/5911</link><guid isPermaLink="true">https://community.m5stack.com/post/5911</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Fri, 11 Oct 2019 19:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Fri, 11 Oct 2019 08:55:22 GMT]]></title><description><![CDATA[<p dir="auto">The jumper / DuPont Female cables can not fit into the Male groove connector because the size of 4 jumpers is larger than the inside size of the groove connector.</p>
]]></description><link>https://community.m5stack.com/post/5907</link><guid isPermaLink="true">https://community.m5stack.com/post/5907</guid><dc:creator><![CDATA[lfleron]]></dc:creator><pubDate>Fri, 11 Oct 2019 08:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Thu, 10 Oct 2019 10:53:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lfleron" aria-label="Profile: lfleron">@<bdi>lfleron</bdi></a> no need to cut if you have jumper/DuPont cables. The go base is the easiest way to connect things together. Invalid port? Looks like i need to check my documents thanks for letting me know</p>
]]></description><link>https://community.m5stack.com/post/5892</link><guid isPermaLink="true">https://community.m5stack.com/post/5892</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 10 Oct 2019 10:53:33 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Thu, 10 Oct 2019 09:05:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
Thanks again for your answers.<br />
I discover this new product which is fantastic to learn.<br />
You say: "While the light sensor can be connected to port A" but if I connect it as indicated in port A M5 says "ERROR invalid Pin for ADC.<br />
I find normal this answer because the porta = I2C and the light sensor are outputs analog and digital so rather for the port B.<br />
The only solution for me will be to buy the gray base to plug into the M5 Black?<br />
Because I do not want to cut the groove wires to connect them directly to the black M5 core pin connectors.<br />
LF</p>
]]></description><link>https://community.m5stack.com/post/5891</link><guid isPermaLink="true">https://community.m5stack.com/post/5891</guid><dc:creator><![CDATA[lfleron]]></dc:creator><pubDate>Thu, 10 Oct 2019 09:05:49 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Wed, 09 Oct 2019 18:54:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lfleron" aria-label="Profile: lfleron">@<bdi>lfleron</bdi></a> said in <a href="/post/5887">Missing module with my core M5 Basic ??</a>:</p>
<p dir="auto">I think that according to the documentation it is rather the PbHub? Because I / O must be converted to a single I2C. We do not want to have more I2C so it's not PaHub?<br />
But on the presentation video is the M5 Core with a gray module below. The person does not use paHub or pbhub in the video in the link: <a href="https://www.youtube.com/watch?v=DgxC_0WGkgk" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=DgxC_0WGkgk</a><br />
Thank you for your answer ;-)</p>
<p dir="auto">Yes the Pbhub sorry typo. Luke is using a gray core which has the go base which has An analog port and a UART.<br />
The core which has a black base has all the pins broken out.<br />
The gray uses the <a href="https://m5stack.com/collections/m5-base/products/battery-bottom-charging-base?ref=pfpqkvphmgr" target="_blank" rel="noopener noreferrer nofollow ugc">go base.</a><br />
Which has two ports and the RGB leds.<br />
While the light sensor can be connected to port A, the relay can not be connected to port A as it causes the m5Stack to reset.<br />
Also the video was made before the hubs,</p>
<p dir="auto">However, both the relay and light sensor can both be connected to port B using a groveT connector as the sensor uses analog0 and the relay usses analog1</p>
]]></description><link>https://community.m5stack.com/post/5888</link><guid isPermaLink="true">https://community.m5stack.com/post/5888</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 09 Oct 2019 18:54:42 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Wed, 09 Oct 2019 18:25:13 GMT]]></title><description><![CDATA[<p dir="auto">I think that according to the documentation it is rather the PbHub? Because I / O must be converted to a single I2C. We do not want to have more I2C so it's not PaHub?<br />
]]></description><link>https://community.m5stack.com/post/5887</link><guid isPermaLink="true">https://community.m5stack.com/post/5887</guid><dc:creator><![CDATA[lfleron]]></dc:creator><pubDate>Wed, 09 Oct 2019 18:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to Missing module with my core M5 Basic ?? on Wed, 09 Oct 2019 18:39:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lfleron" aria-label="Profile: lfleron">@<bdi>lfleron</bdi></a> You need to use the Pbhub to convert analog signals into i2c as the basic only has the i2c port<br />
<a href="https://m5stack.com/collections/m5-unit/products/pb-hub?ref=pfpqkvphmgr" target="_blank" rel="noopener noreferrer nofollow ugc">Pbhub</a><br />
or you can use dupont connectors to connect the sensor and relay to the analogue pins on the bottom of the core basic.</p>
]]></description><link>https://community.m5stack.com/post/5886</link><guid isPermaLink="true">https://community.m5stack.com/post/5886</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 09 Oct 2019 18:39:18 GMT</pubDate></item></channel></rss>
