<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Driver firmware - PbHUB]]></title><description><![CDATA[<p dir="auto">Hello, everyone,<br />
how do you transfer or play new firmware or driver firmware to the Pb.Hub, for example?<br />
"Link: <a href="https://github.com/m5stack/PbHUB/tree/master/PortB_HUB/Firmware/%E4%BA%A7%E5%93%81%E5%9B%BA%E4%BB%B6" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/PbHUB/tree/master/PortB_HUB/Firmware/产品固件</a><br />
??<br />
I bought the ISP stick, but where do you connect it or do i need it not ?<br />
"Link:<a href="https://m5stack.com/collections/m5-accessory/products/isp-usbasp-programmer" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-accessory/products/isp-usbasp-programmer</a>"<br />
An illustrated instruction would not be bad!</p>
<p dir="auto">Greetings Reiner</p>
]]></description><link>https://community.m5stack.com/topic/1368/driver-firmware-pbhub</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:38:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1368.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Oct 2019 07:02:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Driver firmware - PbHUB on Wed, 31 Mar 2021 06:42:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: Skink">@<bdi>Skink</bdi></a> do you still have the source code from   <a href="https://github.com/m5stack/PbHUB/tree/master/PortB_HUB/Firmware" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/PbHUB/tree/master/PortB_HUB/Firmware</a> ?</p>
]]></description><link>https://community.m5stack.com/post/13339</link><guid isPermaLink="true">https://community.m5stack.com/post/13339</guid><dc:creator><![CDATA[emil82]]></dc:creator><pubDate>Wed, 31 Mar 2021 06:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to Driver firmware - PbHUB on Wed, 16 Oct 2019 09:47:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> ,<br />
thank you for the Short answer!!</p>
<p dir="auto">Now I have understood what the ISP program adapter is good for</p>
<p dir="auto">Thx! Reiner</p>
]]></description><link>https://community.m5stack.com/post/6003</link><guid isPermaLink="true">https://community.m5stack.com/post/6003</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Wed, 16 Oct 2019 09:47:50 GMT</pubDate></item><item><title><![CDATA[Reply to Driver firmware - PbHUB on Wed, 16 Oct 2019 08:40:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: Skink">@<bdi>Skink</bdi></a> Short answer: No you don't need it for normal use of any m5stack product. It is only required if there is a major update to any m5stack product that doesn't have a usb port</p>
]]></description><link>https://community.m5stack.com/post/5998</link><guid isPermaLink="true">https://community.m5stack.com/post/5998</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 16 Oct 2019 08:40:05 GMT</pubDate></item><item><title><![CDATA[Reply to Driver firmware - PbHUB on Wed, 16 Oct 2019 07:28:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: skink">@<bdi>skink</bdi></a> the programmer is invade you want to create your own firmware or update existing firmware. Some of the devices use GRBL which often gets updated with new firmware. The servo module and my own servo unit use the same Arduino firmware which can be updated using the adapter. Also the isp can be used when direct usb programming doesn’t work.</p>
]]></description><link>https://community.m5stack.com/post/5996</link><guid isPermaLink="true">https://community.m5stack.com/post/5996</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 16 Oct 2019 07:28:24 GMT</pubDate></item><item><title><![CDATA[Reply to Driver firmware - PbHUB on Wed, 16 Oct 2019 06:16:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a></p>
<p dir="auto">No I didn't want to write my own firmware, only I asked myself what the ISP-USBASP programmer is meant for!<br />
Or do I not need it at all with the M5Stack !?</p>
]]></description><link>https://community.m5stack.com/post/5993</link><guid isPermaLink="true">https://community.m5stack.com/post/5993</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Wed, 16 Oct 2019 06:16:22 GMT</pubDate></item><item><title><![CDATA[Reply to Driver firmware - PbHUB on Tue, 08 Oct 2019 08:40:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: Skink">@<bdi>Skink</bdi></a> the PbHub comes preinstalled with the necessary firmware Are you intending to write custom firmware for the PbHub? Since its not the standard atmega but a much smaller package, I dont think its possible other than to solder some tiny wires directly to the mosi and miso, sck etc pins of the chip which would be difficult considering how small it is</p>
]]></description><link>https://community.m5stack.com/post/5868</link><guid isPermaLink="true">https://community.m5stack.com/post/5868</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 08 Oct 2019 08:40:19 GMT</pubDate></item></channel></rss>
