<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screen orientation on UI flow]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I would like to know if there is any way to change the screen rotation on the UI flow designer for the m5stick-c.<br />
The function "set screen rotate mode" seems to work but it is not reflected on the UI for the design part.<br />
Therefore this image is not rotated properly. Does that mean it has to be done manually ? (ie rotating the jpg before importing it)</p>
<p dir="auto">Thanks by advance for your feedback.<br />
Regards,<br />
Antowan</p>
]]></description><link>https://community.m5stack.com/topic/1281/screen-orientation-on-ui-flow</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 10:21:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1281.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Sep 2019 05:51:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screen orientation on UI flow on Tue, 03 Sep 2019 04:46:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Thank you for your quick answer, I have imported the JPG pre-rotated for the moment and it works fine.</p>
]]></description><link>https://community.m5stack.com/post/5434</link><guid isPermaLink="true">https://community.m5stack.com/post/5434</guid><dc:creator><![CDATA[antowan]]></dc:creator><pubDate>Tue, 03 Sep 2019 04:46:39 GMT</pubDate></item><item><title><![CDATA[Reply to Screen orientation on UI flow on Mon, 02 Sep 2019 17:57:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1996">@antowan</a> It is better to have the image in the correct orientation before importing to the M5Stick or stick.</p>
<p dir="auto">The Block for screen rotation has only just been added to UIFlow.</p>
]]></description><link>https://community.m5stack.com/post/5430</link><guid isPermaLink="true">https://community.m5stack.com/post/5430</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 02 Sep 2019 17:57:30 GMT</pubDate></item></channel></rss>
