<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My M5stack can&#x27;t connect to WiFi.(SOLVED)]]></title><description><![CDATA[<p dir="auto">Hello, I have a connection problem that my M5Stack can't connect to Wifi. I erased flash and successfully burned UIFlow-v1.3.2. I selected "Set WiFi via AP" mode and I connected 192.168.4.1 then entered my Wifi password but it failed always, never success. I tried more than 20times but no success. Please help me to solve this issue. Any advise, suggestion would be appreciated. Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/1252/my-m5stack-can-t-connect-to-wifi-solved</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 15:06:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1252.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Aug 2019 05:30:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Wed, 06 Nov 2024 01:53:29 GMT]]></title><description><![CDATA[<p dir="auto">This work to me.</p>
<p dir="auto">I added Wifi%home%name%9900 and work</p>
]]></description><link>https://community.m5stack.com/post/26968</link><guid isPermaLink="true">https://community.m5stack.com/post/26968</guid><dc:creator><![CDATA[silasrsilveira]]></dc:creator><pubDate>Wed, 06 Nov 2024 01:53:29 GMT</pubDate></item><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Tue, 02 Feb 2021 18:08:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zolfrik" aria-label="Profile: zolfrik">@<bdi>zolfrik</bdi></a> said in <a href="/post/6782">My M5stack can't connect to WiFi.(SOLVED)</a>:</p>
<p dir="auto">Hi, I don't know if this problem has been already fixed, but I found a solution few days ago. The problem is caused by wrong url encoding made by M5Stack: it encodes the white space with a "+" instead of a "%20". You can manually edit the generated url replacing the "+" with "%20" (without quotes) and it will connect to the wifi.</p>
<p dir="auto">this solution works!! Thanks a lot!</p>
]]></description><link>https://community.m5stack.com/post/12264</link><guid isPermaLink="true">https://community.m5stack.com/post/12264</guid><dc:creator><![CDATA[hei72]]></dc:creator><pubDate>Tue, 02 Feb 2021 18:08:21 GMT</pubDate></item><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Fri, 27 Dec 2019 15:51:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I don't know if this problem has been already fixed, but I found a solution few days ago. The problem is caused by wrong url encoding made by M5Stack: it encodes the white space with a "+" instead of a "%20". You can manually edit the generated url replacing the "+" with "%20" (without quotes) and it will connect to the wifi.</p>
]]></description><link>https://community.m5stack.com/post/6782</link><guid isPermaLink="true">https://community.m5stack.com/post/6782</guid><dc:creator><![CDATA[ZolfriK]]></dc:creator><pubDate>Fri, 27 Dec 2019 15:51:36 GMT</pubDate></item><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Fri, 30 Aug 2019 02:14:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boneskull" aria-label="Profile: boneskull">@<bdi>boneskull</bdi></a> What fix would you propose? you could submit it in the issues of the uiflow micropython repo on github <a href="https://github.com/EeeeBin/UIFlow-Firmware/tree/beta" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/EeeeBin/UIFlow-Firmware/tree/beta</a></p>
]]></description><link>https://community.m5stack.com/post/5379</link><guid isPermaLink="true">https://community.m5stack.com/post/5379</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Fri, 30 Aug 2019 02:14:57 GMT</pubDate></item><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Thu, 29 Aug 2019 22:05:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Can I contribute a fix somewhere?  I don't have the option of changing my SSID.</p>
]]></description><link>https://community.m5stack.com/post/5377</link><guid isPermaLink="true">https://community.m5stack.com/post/5377</guid><dc:creator><![CDATA[boneskull]]></dc:creator><pubDate>Thu, 29 Aug 2019 22:05:42 GMT</pubDate></item><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Mon, 26 Aug 2019 01:53:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thank you so much. There was a space in my SSID. I changed it removing a space and now M5stack can connect to WiFi. Thank you again!</p>
]]></description><link>https://community.m5stack.com/post/5294</link><guid isPermaLink="true">https://community.m5stack.com/post/5294</guid><dc:creator><![CDATA[Kazunkm]]></dc:creator><pubDate>Mon, 26 Aug 2019 01:53:27 GMT</pubDate></item><item><title><![CDATA[Reply to My M5stack can&#x27;t connect to WiFi.(SOLVED) on Sun, 25 Aug 2019 06:37:22 GMT]]></title><description><![CDATA[<p dir="auto">Is there a space in the Wifi name?<br />
M5stack can't access wifi networks with spaces in the SSID</p>
]]></description><link>https://community.m5stack.com/post/5291</link><guid isPermaLink="true">https://community.m5stack.com/post/5291</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 25 Aug 2019 06:37:22 GMT</pubDate></item></channel></rss>
