<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Burn Ui Flow Firmware]]></title><description><![CDATA[<p dir="auto">I have just received a M5StickC and am trying to install stickC 1.3.2 uiflow firmware and I get the following error -<br />
A fatal error occurred: Timed out waiting for packet header<br />
I have checked the Comm port and baud rate is correct because the erase in M5Burner worked correctly. There is an old forum post about adding a capacitor between RST and GRD, is this still necessary?</p>
]]></description><link>https://community.m5stack.com/topic/1151/burn-ui-flow-firmware</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 21:50:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1151.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jul 2019 13:30:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Burn Ui Flow Firmware on Mon, 29 Jul 2019 01:34:20 GMT]]></title><description><![CDATA[<p dir="auto">if you tried with 115200, and no success, that would be necessary.</p>
]]></description><link>https://community.m5stack.com/post/4883</link><guid isPermaLink="true">https://community.m5stack.com/post/4883</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 29 Jul 2019 01:34:20 GMT</pubDate></item></channel></rss>
