<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cp210x.ko driver - invalid module format]]></title><description><![CDATA[<p dir="auto">Has anyone encounter similar problem in Ubuntu?</p>
<p dir="auto">insmod: ERROR: could not insert module /lib/modules/4.13.0-35-generic/kernel/drivers/usb/serial/cp210x.ko: Invalid module format</p>
]]></description><link>https://community.m5stack.com/topic/114/cp210x-ko-driver-invalid-module-format</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 09:30:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/114.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Feb 2018 12:01:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cp210x.ko driver - invalid module format on Sat, 24 Feb 2018 22:10:04 GMT]]></title><description><![CDATA[<p dir="auto">I gave it a go using all esp-idf components and a program without M5Stack. I then hit the command,  "make flash monitor". The result is as what you said. Awesome!</p>
<p dir="auto">I would like use your source to get the TFT LCD screen to work first. Do you have any advise for me that I should aware, avoid, etc, please?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/post/456</link><guid isPermaLink="true">https://community.m5stack.com/post/456</guid><dc:creator><![CDATA[lim]]></dc:creator><pubDate>Sat, 24 Feb 2018 22:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to cp210x.ko driver - invalid module format on Sat, 24 Feb 2018 19:17:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/176">@lim</a></p>
<p dir="auto"><strong>cp210x</strong> driver on Ubuntu works without any problem.<br />
There is <strong>no difference</strong> between M5Stack and other ESP32 boards using the same USB to UART chip (related to the communication with the PC).<br />
I can <strong>communicate</strong> with the M5Stack same as with other ESP32 boards I have (flash, terminal, etc.).<br />
Built applications <strong>runs</strong> the same on M5Stack as on other ESP32 boards I have.</p>
<p dir="auto">There is <strong>nothing specific</strong> to M5Stack which should cause behaviour different than other ESP32 boards.</p>
]]></description><link>https://community.m5stack.com/post/455</link><guid isPermaLink="true">https://community.m5stack.com/post/455</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Sat, 24 Feb 2018 19:17:46 GMT</pubDate></item><item><title><![CDATA[Reply to cp210x.ko driver - invalid module format on Sat, 24 Feb 2018 18:48:13 GMT]]></title><description><![CDATA[<p dir="auto">Did you refer to the driver or the M5Stack-idf? All my esp-idf drivers and examples as well as the Webradio Bluetooth Speaker work without any issues. Can you be more specific, please?</p>
]]></description><link>https://community.m5stack.com/post/453</link><guid isPermaLink="true">https://community.m5stack.com/post/453</guid><dc:creator><![CDATA[lim]]></dc:creator><pubDate>Sat, 24 Feb 2018 18:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to cp210x.ko driver - invalid module format on Sat, 24 Feb 2018 17:55:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/176">@lim</a><br />
M5Stack works without problem on Ubuntu 17.10 &amp; Ubuntu 16.04.<br />
Maybe something is wrong with your Ubuntu instalation?</p>
]]></description><link>https://community.m5stack.com/post/452</link><guid isPermaLink="true">https://community.m5stack.com/post/452</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Sat, 24 Feb 2018 17:55:29 GMT</pubDate></item></channel></rss>
