<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[bmm15 on ENV module for M5StickC not working]]></title><description><![CDATA[<p dir="auto">I got my recent order today and instantly tested all components.</p>
<p dir="auto">Unfortunately there is one issue in the ENV hat for the M5StickC.</p>
<p dir="auto">The DHT12 sensor is working as well as the BMP280 but the bmm15 is not showing up.</p>
<p dir="auto">A scan of the i2c bus shows that the device is not present at all.</p>
<p dir="auto">Scanning...<br />
I2C device found at address 0x5C  ! (this is the dht12)<br />
I2C device found at address 0x76  ! (this is the bmp280)<br />
Found total 2 devices</p>
<p dir="auto">Does anyone else have this issue and probably a solution before I contact the store for an itemreplace?</p>
Chris</p>
]]></description><link>https://community.m5stack.com/topic/1122/bmm15-on-env-module-for-m5stickc-not-working</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 07:03:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1122.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jul 2019 12:26:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to bmm15 on ENV module for M5StickC not working on Tue, 09 Jul 2019 06:01:22 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your replies, i tried the proposed arduino example and unfortunately got the same results - no response from the bmm.</p>
<p dir="auto">I will contact the shop</p>
<p dir="auto">have a nice day<br />
Chris</p>
]]></description><link>https://community.m5stack.com/post/4781</link><guid isPermaLink="true">https://community.m5stack.com/post/4781</guid><dc:creator><![CDATA[MrTarantl]]></dc:creator><pubDate>Tue, 09 Jul 2019 06:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to bmm15 on ENV module for M5StickC not working on Tue, 09 Jul 2019 02:36:07 GMT]]></title><description><![CDATA[<p dir="auto">Try arduino hat env example, if it also not work, please contact the store</p>
]]></description><link>https://community.m5stack.com/post/4778</link><guid isPermaLink="true">https://community.m5stack.com/post/4778</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Tue, 09 Jul 2019 02:36:07 GMT</pubDate></item><item><title><![CDATA[Reply to bmm15 on ENV module for M5StickC not working on Mon, 08 Jul 2019 16:30:14 GMT]]></title><description><![CDATA[<p dir="auto">What software are you using?<br />
OK, just check the latest UIFlow and it's not enabled in the code yet.</p>
]]></description><link>https://community.m5stack.com/post/4774</link><guid isPermaLink="true">https://community.m5stack.com/post/4774</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 08 Jul 2019 16:30:14 GMT</pubDate></item></channel></rss>
