<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to program the M5stack fire RGB LEDs SK6812]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I am kind of lost in programming the M5Stack-FIRE built in LEDs in Arduino IDE and would need some basic help.<br />
Specific questions:</p>
<li>Which library should be used?</li>
<li>Are there any working examples available?</li>
<li>Is there any specific documentation for that?</li>
<p dir="auto">Thanks - grelm</p>
]]></description><link>https://community.m5stack.com/topic/1068/how-to-program-the-m5stack-fire-rgb-leds-sk6812</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 00:22:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1068.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Jun 2019 17:03:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to program the M5stack fire RGB LEDs SK6812 on Tue, 23 Nov 2021 18:41:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> No it's not a Grove pin.<br />
Check here:<br />
<a href="https://github.com/m5stack/m5-docs/blob/master/docs/en/core/fire.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5-docs/blob/master/docs/en/core/fire.md</a></p>
]]></description><link>https://community.m5stack.com/post/15573</link><guid isPermaLink="true">https://community.m5stack.com/post/15573</guid><dc:creator><![CDATA[hague]]></dc:creator><pubDate>Tue, 23 Nov 2021 18:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to How to program the M5stack fire RGB LEDs SK6812 on Mon, 10 Jun 2019 10:45:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1539">@grelm</a> I would normally have said the adafruit libs but I keep reading that fastled is well, faster.<br />
If you look in the docs there should be some listings for the pin outs but normally RGB leds are connected to Grove Port A the red port.</p>
]]></description><link>https://community.m5stack.com/post/4579</link><guid isPermaLink="true">https://community.m5stack.com/post/4579</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 10 Jun 2019 10:45:01 GMT</pubDate></item><item><title><![CDATA[Reply to How to program the M5stack fire RGB LEDs SK6812 on Mon, 10 Jun 2019 10:28:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot to <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> !<br />
Your feedback with fastled and the libs was very helpful and gave me the necessary hint on how to move forward.<br />
Finally I ended up playing around with Adafruit_NeoPixel - now I am able to use and control the M5Stack-FIRE-LED's as I want.<br />
The most important fact (which I didn't find out before) was, that the DATA_PIN for the LED'S is Pin 15.<br />
Just in case of future issues: where in the M5Stack-FIRE-documents can I find such detailed informations about the M5Stack hardware?</p>
]]></description><link>https://community.m5stack.com/post/4578</link><guid isPermaLink="true">https://community.m5stack.com/post/4578</guid><dc:creator><![CDATA[grelm]]></dc:creator><pubDate>Mon, 10 Jun 2019 10:28:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to program the M5stack fire RGB LEDs SK6812 on Sun, 09 Jun 2019 17:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1539">@grelm</a> the fastled is normally recommended and there should be examples in arduino.<br />
have you installed al the m5stack libs?</p>
]]></description><link>https://community.m5stack.com/post/4571</link><guid isPermaLink="true">https://community.m5stack.com/post/4571</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 09 Jun 2019 17:24:47 GMT</pubDate></item></channel></rss>
