<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is M5Cloud down?]]></title><description><![CDATA[<p dir="auto">I havn't been able to connect to <a href="http://io.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">io.m5stack.com</a> nor <a href="http://cloud.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">cloud.m5stack.com</a>. Is it offline or am I having problems? It worked fine yesterday.</p>
]]></description><link>https://community.m5stack.com/topic/104/is-m5cloud-down</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 14:51:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/104.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Feb 2018 02:47:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is M5Cloud down? on Thu, 03 May 2018 19:12:22 GMT]]></title><description><![CDATA[<p dir="auto">Concise code for sure. I need all the speed I can get so it'll be Arduino for now.<br />
I'm surprised you wouldn't see any flicker on the display since you print every frame, also surprised that there is no clearScreen preceding the print. I'm thinking the python print has a background.</p>
]]></description><link>https://community.m5stack.com/post/940</link><guid isPermaLink="true">https://community.m5stack.com/post/940</guid><dc:creator><![CDATA[daslolo]]></dc:creator><pubDate>Thu, 03 May 2018 19:12:22 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Thu, 03 May 2018 14:32:36 GMT]]></title><description><![CDATA[<p dir="auto">posted my first MicroPython Code here :</p>
<p dir="auto"><a href="http://forum.m5stack.com/topic/197/micropython-clock-task-with-rtc-and-ntp-sync" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/197/micropython-clock-task-with-rtc-and-ntp-sync</a></p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/281">@daslolo</a><br />
So, feel free to compare by yourself with Arduino.<br />
The "Clock" code does it all for me on displaying time (and date if needed),  and if synced to NTP with green or red time digits. Just as a task in the background.</p>
]]></description><link>https://community.m5stack.com/post/937</link><guid isPermaLink="true">https://community.m5stack.com/post/937</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Thu, 03 May 2018 14:32:36 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Thu, 03 May 2018 14:18:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/269">@calin</a><br />
ok.</p>
<p dir="auto">Good point, I came from ATMega and ARM Arduino with "Standard" Arduino knowledge and was totally surprised that M5STACK MicroPython is running FreeRTOS.</p>
<p dir="auto">I will also review your links.</p>
<p dir="auto">Just new to MicroPhyton, I just collected some code pieces in the web to get a "Clock" background task coded with RTC and NTP Sync by just some code lines.<br />
BTW. No flickering on the display etc.</p>
]]></description><link>https://community.m5stack.com/post/935</link><guid isPermaLink="true">https://community.m5stack.com/post/935</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Thu, 03 May 2018 14:18:00 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Thu, 03 May 2018 05:51:00 GMT]]></title><description><![CDATA[<p dir="auto">ESP32 Arduino IDF also run's RTOS.<br />
Check the main.cpp on arduino-idf:</p>
<p dir="auto">void loopTask(void *pvParameters)<br />
{<br />
setup();<br />
for(;;) {<br />
micros(); //update overflow<br />
loop();<br />
}<br />
<p dir="auto">extern "C" void app_main()<br />
{<br />
initArduino();<br />
xTaskCreatePinnedToCore(loopTask, "loopTask", 8192, NULL, 1, NULL, ARDUINO_RUNNING_CORE);<br />
<p dir="auto">You can create tasks on any core you chose by calling RTOS xTaskCreatePinnedToCore function anywhere in your arduino sketch.</p>
<p dir="auto">You can also change the tasks priorityes, define stack size, use queues, semaphores, mutexes, and all other RTOS features. For OTA you have options to chose from:</p>
<li>Local OTA (upload the firmware without usb cable while M5 is on local network)</li>
<li>Remote OTA: Set the M5 to auto update once a condition is met (like a new firmware version available) like i did on my MultiApp Advanced: <a href="http://forum.m5stack.com/topic/194/m5stack-multiapp-advanced-firmware" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/194/m5stack-multiapp-advanced-firmware</a> . This way you can update the M5Stack even if is on the other side of the planet.</li>
<p dir="auto">All this without the overhead of an interpreter...</p>
]]></description><link>https://community.m5stack.com/post/933</link><guid isPermaLink="true">https://community.m5stack.com/post/933</guid><dc:creator><![CDATA[Calin]]></dc:creator><pubDate>Thu, 03 May 2018 05:51:00 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Wed, 02 May 2018 20:16:35 GMT]]></title><description><![CDATA[<p dir="auto">@jimit<br />
<a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/281">@daslolo</a></p>
<p dir="auto">MicroPython VS Arduino is no comparison of equals</p>
<p dir="auto">MPY is running FreeRTOS  as uOS and so you have total different opportunities.<br />
Best of these for my IoT Application will be Over the Air updating with low amount of traffic.<br />
As only packages of text (code) will be sent; the traffic is low and update faster than Arduino USB connection (even without compiling).</p>
<p dir="auto">So I look forward for an adventure switching from Arduino to MicroPython with M5STACK,</p>
<p dir="auto">If you ever considered running multiple thread or tasks - for sure give it a try.<br />
If you just want to learn something new, the same. ;-)</p>
<p dir="auto">Cheers</p>
]]></description><link>https://community.m5stack.com/post/929</link><guid isPermaLink="true">https://community.m5stack.com/post/929</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Wed, 02 May 2018 20:16:35 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Wed, 02 May 2018 18:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/281">@daslolo</a> <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/345">@M5MPy</a></p>
<p dir="auto">Hi Daslolo,</p>
<p dir="auto">Unfortunately I haven't had time to use the M5Cloud to any great extent....   now I have the software flashed to an M5 again I will check it out...</p>
<p dir="auto">Perhaps M5MPy can respond ?  M5Cloud vs. arduino ide vs. platformIO.</p>
<p dir="auto">Over the air (wireless) updating of the software is cool  (M5Cloud).....</p>
]]></description><link>https://community.m5stack.com/post/927</link><guid isPermaLink="true">https://community.m5stack.com/post/927</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Wed, 02 May 2018 18:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Wed, 02 May 2018 10:20:45 GMT]]></title><description><![CDATA[<p dir="auto">@jimit 在 <a href="/post/922">Is M5Cloud down?</a> 中说：</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/345">@m5mpy</a> Great to hear... thanks for updating status....</p>
<p dir="auto">you use cloud? how does it compare with arduino ide or ... platformIO<br />
Calun should pop in any time now ;)</p>
]]></description><link>https://community.m5stack.com/post/925</link><guid isPermaLink="true">https://community.m5stack.com/post/925</guid><dc:creator><![CDATA[daslolo]]></dc:creator><pubDate>Wed, 02 May 2018 10:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Wed, 02 May 2018 08:30:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/345">@m5mpy</a> Great to hear... thanks for updating status....</p>
]]></description><link>https://community.m5stack.com/post/922</link><guid isPermaLink="true">https://community.m5stack.com/post/922</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Wed, 02 May 2018 08:30:35 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Tue, 01 May 2018 22:20:28 GMT]]></title><description><![CDATA[<p dir="auto">Back online and running again. Thx</p>
]]></description><link>https://community.m5stack.com/post/921</link><guid isPermaLink="true">https://community.m5stack.com/post/921</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Tue, 01 May 2018 22:20:28 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Tue, 01 May 2018 12:36:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/345">@m5mpy</a></p>
<p dir="auto">No problem for the update. I'm sure they will do all they can to get it working ASAP.....</p>
]]></description><link>https://community.m5stack.com/post/917</link><guid isPermaLink="true">https://community.m5stack.com/post/917</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Tue, 01 May 2018 12:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Tue, 01 May 2018 11:51:45 GMT]]></title><description><![CDATA[<p dir="auto">@jimit<br />
Thanks for the update.<br />
Also changed down to .38 upfront posting, but no change, the same as you mentioned.<br />
So used FTP and REPL on .39 since.<br />
Also hope they get M5Cloud working again soon, as I changed to MicroPython just recently and really enjoy it. ;-)</p>
]]></description><link>https://community.m5stack.com/post/916</link><guid isPermaLink="true">https://community.m5stack.com/post/916</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Tue, 01 May 2018 11:51:45 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Tue, 01 May 2018 00:56:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/345">@m5mpy</a></p>
<p dir="auto">Someone on twitter reported similar issues to M5Stack late last night.... so they are aware  of it.</p>
<p dir="auto">I had issues with version 0.3.9 and dropped down to 0.3.8 as per their suggestion, but still had similar issues to yours.</p>
<p dir="auto">So hopefully it will be resolved soon.</p>
]]></description><link>https://community.m5stack.com/post/915</link><guid isPermaLink="true">https://community.m5stack.com/post/915</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Tue, 01 May 2018 00:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Mon, 30 Apr 2018 22:30:14 GMT]]></title><description><![CDATA[<p dir="auto">TTY snip for explanation :</p>
<p dir="auto">MicroPython ESP32_LoBo_v3.2.11 - 2018-04-16 on M5Stack with ESP32<br />
Type "help()" for more information.<br />
&lt;&gt;&gt; [M5-30xxxyyyyyyy] M5Cloud connected.<br />
[M5Cloud] Uploading:/flash/config.json  .<br />
[M5Cloud] Uploading:/flash/main.py  .<br />
[M5Cloud] Uploading:/flash/boot.py  .&gt; M5 is connecting now ..</p>
<p dir="auto">and IDE freezes</p>
]]></description><link>https://community.m5stack.com/post/913</link><guid isPermaLink="true">https://community.m5stack.com/post/913</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Mon, 30 Apr 2018 22:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Mon, 30 Apr 2018 22:24:00 GMT]]></title><description><![CDATA[<p dir="auto">@jimit ok, thx<br />
M5 is connecting now ..<br />
But still on the Cloud the IDE does not stop or exit out of "File Syncing ..." mode, even though I can see in the terminal (USB) that the *.py files have been loading fast.<br />
Any thoughts ?</p>
]]></description><link>https://community.m5stack.com/post/912</link><guid isPermaLink="true">https://community.m5stack.com/post/912</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Mon, 30 Apr 2018 22:24:00 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Mon, 30 Apr 2018 19:53:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/345">@m5mpy</a>  Seems to be up now.....</p>
]]></description><link>https://community.m5stack.com/post/911</link><guid isPermaLink="true">https://community.m5stack.com/post/911</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Mon, 30 Apr 2018 19:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Mon, 30 Apr 2018 18:40:36 GMT]]></title><description><![CDATA[<p dir="auto">Down again since last night ?<br />
M5 responds connection failed ?</p>
]]></description><link>https://community.m5stack.com/post/907</link><guid isPermaLink="true">https://community.m5stack.com/post/907</guid><dc:creator><![CDATA[M5MPy]]></dc:creator><pubDate>Mon, 30 Apr 2018 18:40:36 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Sun, 18 Feb 2018 23:07:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/12833">@bin</a> It is up now, but not working as great as a few days ago. Code will only upload around 1 out of every 5 tries. And sometimes the M5stack randomly decides to download some new code and restart.</p>
]]></description><link>https://community.m5stack.com/post/405</link><guid isPermaLink="true">https://community.m5stack.com/post/405</guid><dc:creator><![CDATA[Kjolstad]]></dc:creator><pubDate>Sun, 18 Feb 2018 23:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Sun, 18 Feb 2018 06:50:10 GMT]]></title><description><![CDATA[<p dir="auto">Sorry for that, we have fixed the server.</p>
]]></description><link>https://community.m5stack.com/post/399</link><guid isPermaLink="true">https://community.m5stack.com/post/399</guid><dc:creator><![CDATA[0x1abin]]></dc:creator><pubDate>Sun, 18 Feb 2018 06:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Is M5Cloud down? on Sun, 18 Feb 2018 03:07:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/191">@kjolstad</a> Hi, I also cannot connect to either address so there must some issue there. Hopefully resolved soon.</p>
]]></description><link>https://community.m5stack.com/post/396</link><guid isPermaLink="true">https://community.m5stack.com/post/396</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 18 Feb 2018 03:07:40 GMT</pubDate></item></channel></rss>
